No wheelies with a beast ???
xll-SavageX-llx
★ CaNaDa Eh ★
Hamilton Ontario
What's up guys. been a while, cought up with school and stuff.. I want to ask a question pick everyones brain for a bit muhahah ..
I'm currently running the ERCM K4.6 HO with the ERCM side bleed, 2sp trans, 18/47, flm ext savy, 250cc mid tank. I took her out for a run the other day put 2 tanks on her and i CAN'T wheelie =(
Brang the savy back inside and took the front drive shaft out and even with that it still wouldn't wheelie. There is a nice tune on the mill, thin train of blue smoke, getting lots of fuel, and temps are 210-230 ish, "cold start" it will take 1 pull. Running the big bores with 35w all three spacers and the pre-load clip.. Only thing i can think is the power isn't going to wheels i.e diffs not maintained with fluid :lmao:
I should check the diffs now i think of it ...
Brandon
you got a pretty tall gear with lots of weight in the front, reduce the teeth on the clutch bell, or try while low on fuel, and a little lighter in the front end
I know what you mean but i went by hand and lifted up the front end and then the back end there pretty much the same . It's like i can put the 250cc fuel tank in the back of truck I'm not sure what i can take off the front to reduce weight LOL
i well set up truck is actually meant not to wheelie. You should be happy, all the power to the ground, no hassle of no control. lol but i know what you mean wheelies are still fun.
(i well set up truck is actually meant not to wheelie.)
English Translation ::
"The way this truck is set up it's not meant to wheelie"
am i close :lmao:
I know with th ext tvps and the mid tank it will take alot more to wheelie, speed is not a problem with this truck it's mad fast, just to wheelies =(
Maybe there is a gearing that will give me my speed but if i punch the throttle it will stand up ??
can you post a vid? my F4.6 jacked my flm truck right into wheelies on 17/47 after crash modded it (250cc), almost backflipped after bank modded it. it tempt out around 260-265 when tuned right.
Picco did it on 18/47
can you post a vid? I'm still thinking your tune is too rich. But if your saying its at the cusp of being tuned too lean at 230f, sounds like you got a problem with that mill.
vid would give everyone a better idea to help you out 😉
When i was breaking it in i called up Robin i told him it's been running for 5 minutes with the hsn turned in 2 turns from stock on the first tank and the temp was like 180 he said lean it out so i did another half turn and the temp was 210, now it's tuned up it's running 230-235 ish ...
