Newbie needs gearing help for Jumbo Kongs
4.6 BigBlock
What parts do I need to get my gear ratio back to stock or even a bit lower, with my new jumbo kongs ? I don't even know where to start. My truck is a Savage 4.6 RTR. Thanks !
The Kong's look cool but IMO there to big and can cause unwanted stress on your diffs, tranny, and clutch, slipperclutch,dogbones, ect ect
But too anweser your ?
15 tooth clutch bell w/ a 52 tooth spur gear. Is what you what need
The review X 4.6 came with the 47/17 gearing which had the red body
I think they have two different gearings depending if you get the red or blue body, not sure though.
Stock Gears
My stock K 4.6 is a kit version but it does have the 47/17 stock gears.Hope this helps.Jesters rigt though you probably want the 52/15 s with that much rubber.Good luck.
I have the 4.6 X RTR with the blue body and it came with 47/17 gears. Not sure about the red body.
Stock for a 4.6 (don't quote me on this) b/c I don't have a 4.6
But I think it's 47/17
You would be correct SJ.
The 17 is actually pretty crummy because you really can't use it well with anything other than the 47t.
I am using a 15/52t and I can wheelie with the Goliath tires.
ive seen before on the forum were theres a crossguide to reverence the bells and the spur gears ill try to find it . I'm running now a 17/49and i like it
the red 4.6 is 17/47 stock
I have this I can post once I get home if you cannot find it.
Here it is:
Thank you guys alot for all your help, I have already learned a bunch here!
Also, just stuck my Jumbo Kongs on last night and raised my body up higher. The thing is a beast now !
One more question. Are my stock clutch bell and spur gear plastic or metal on a Savage X ?
Pics?
Metal (not hardened) clutchbell and plastic spur on RTR and metal on SS.
