Needles break in, which one to adjust?
usually the high needle, if it is idling ok and you just need a bit more temp lean the high end a tiny bit at a time to help increase the temps a bit....
So I'm doing the tessman break in process which is just running 10 tanks through the motor. After the 10 tanks should I tune the motor or leave it where it's at and run it easy for a couple mor tanks
