Make sure you get some heavier springs to go with the alloy shoes. Like a 1mm or the gold Hpi springs. I just installed a set of aluminum shoes, with stock springs they were engaging way too early. Causing it to be really sluggish off the line. Stiffer springs got the revs up a bit before they engaged, made er nice and snappy!That may be the prob I think the shoes are soaked in fuel gonna try new aluminum ones
When running taller gearing (17/47 +) and a high torque engine, alloy shoes really help get the power to the ground. I used composite shoes for years with older/weaker engines (OS21RG, XTM247...), but when I put in the LRP28 and upped my gearing to 17/47, the shoes just couldn't hold up, especially in grass. Lots of slippage/overheating of the bell. Had the same issue with the same engine on my big block revo using the same 1/8 composite shoes/bell. Now I run alloy shoes on both and they do a lot better.Are aluminum shoes better
Definitely not slow in first. Should be alot of torque there. Definitely sounds like a slippage issue, so the slipper clutch or the clutch shoes are likely worn.
If the slipper is torqued all the way it wouldn't stop that does it need the slipper ?
