need some guidance
iknownothing
been doing some reading here but need some assistance.
i am running a stock savage 4.6 .
front wheels do not return to the ground as quick as id like . also I'm 3 wheeling at times. whats the best front suspension changes you guys recommend
most of my driving is bashing and jumping but my daughter drives as well and she likes the throttle
whats the advantage to the 4 shock setup i see alot vs the factory supplied 8
your suspension may be binding remove the shocks from the arm and see if they move freely. are the arms stock or rpm, rpm's need some work to get them to move freely.
did you get it new or used? have you checked the diffs for fluid?
your best suspension changes would be big bore shocks and then if you want the RSC, you can find the stock plastic big bore relatively cheap on :ebay:
steering mod: https://www.hpisavageforum.com/forums/showthread.php?t=11484
