Need new shocks, Which ones to get?
Well, I can tell you that I owned a full set a found that putting all 8 on posed issues with the shocks rubbing on the turnbuckles and a-arms.
Fortunately, The shocks a real beefy and have stiff springs that can support the the truck just fine.
So I split the set with a friend and mounted the shocks in the the front, behind the upper a-arms.
And for the rear, I mounted the shocks ahead of the a-arms.
They come in purple or silver.
I'll post some pics here so you can see them.
============== HERE YA GO. HOPE THIS HELPS ==================
I had that problem after i put my chassis on but i realized that they were acctually to tight. You should have them a tad bit loose then they wont rub.
I ended up changing the hardware and installing standoffs that Savagecre put together.
That took care of the first four shocks.
