need help
  • Thread starter Thread starter trebreeden
  • Start date Start date
T
trebreeden
Guest
so i was driving my car and its not pulling because the clutch bell not touching the spur gear how can i ajust the height for it can touch
The height isn't adjustable. You need to lossen the screws securing the motor mount to the plate and slide it towards the SG. Use a strip of paper from the manual that came with the truck to set your gear mesh unless you feel comfortable settng it by feel. That's what most members do if they have been in the RC game for awhile. All you need is a slight amount of play between the CB and SG. Also, locktite the screws securing the motor mount to the plate.
Igot it moving now but the slipper gear keep engaging it won't pull a lot but I tighten it yestersai now its bac loose
I'm a beginner but when i tightened my spur gear its still doing the same thing and i searched it up its some type of glue
when i say this i mean it in the upmost nicest way k...
STOP posting & start reading threads on HPISF!!!
there is SOOOO much useful info on here and it will help you!!
they don't have wat I'm looking for I'm trying to find out why my savage making a slipping sound
go to the autoparts store and get yourself blue locktite, you can use that on the slipper assembly although I never have. I usually just tighten the slipper down all the way and not back it out any. as for your motor I would suggest buying 4mm split lock washers, you can get them at a local hardware store and use them along with locktite to secure your motor mount to the motor plate. while your getting 4mm lock washers id get some 3mm lock washers also and use them on the screws that hold your motor onto the motor mounts with locktite. that will greatly minimize any chance of your motor moving under stress. your lucky you didnt eat up a spur and or destroy your clutchbell as your motor slid away from the spur.
i already did that swamp. i drove it for a day and the next day it was loose but I'm going to try that f1n
