Need help with servo problem
freddysrevenge
I have recently bought my HPI savage second hand. When it arrived I wanted to change the receiver so it would work with my current controller. I did this and the steering servo did not work so i bought a new servo and fitted it. This servo still doesent work. Any ideas on what could be the problem?
Cheers
1st things 1st............................Welcome to the forum freddy; :jamout:
couple questions for ya:
you said you changed the receiver & the steer servo dint work: did the t/b servo work after you changed the receiver?
did both servos work with the old Rx before you changed to the new Rx?
what radio equipment & servos are you using?
sounds like the help you need is already here but thought i would take the time to say hello!! and welcome to the forum my friend!!!!!!
Mickey - I was told it did work but i don't know for sure. Is it possible for just one of the receiver channels not to be working?
Frddyj- Not too sure what t/b means. But am presuming you mean the throttle servo in which case yes it did work. I'm not sure if they both worked as i didnt have a working controller to test them. I was told they worked when i bought the savage. The new servo i bought for the steering was a Hitec HS-645mg and the throttle servo is just the standard HPI Servo.
Thanks all for the warm welcome to the forum!
