need help to diagnois a problem with my savage
psd2802
i have posted on utube for help if you follow this it will explain and show you not sure if its the transmishion servo or brakes
By the look in the vid your brakes are on all the time, adjust the linkage to allow the truck to free roll.. should be the same in forward or reverse...
i was out playing with it i put the throttle on to high it took of i slammed the brakes now they are on contantly on unless i press the lever ivthink i blew something I understand adjusting it but I don't know why my controller doesn't work and it is paired
Bind the remote to the receiver first. Make sure all your batteries are full! That servo will center itself when powered on. The brakes are locked up at the moment
