mosaics12 savy build
mosaics12
I'm startin a my build should be basher ;-)
i have a savy x that ill be usin as a donor parts
i have a d8t tank
on motor I'm leanin on lrp .28
will be addin more parts as we go on
here is the startin parts
any suggestion will be greatly appreciated 🙂
You should hold off on the motor. I think the new lrp .32 is gonna be sick. It'll be out next week. Ive got it pre ordered.
29/9 diffs are a must as well, and the two speed outta the x ss have all metal gears.
here is the donor truck w/ miss match tires. lol
starting tearin them down and cleanin up. this is what i find. any recommendation?
also need to upgrade the brakes
thanks
here is the d8t tank and rpm receiver cover. I'm goin to use. anyone knows what item/part# of radio shack box? i might use that since it fit inside next to tank
mosaics if you looked at my build for the idea with the radio shack box , the box is called a small project box and it is very tight to get beside the tank, it does require some dremiling to make it clear.
build is looking good so far
after a few hours workin on it this is how it look now.
finish the rear end. change the bearings, diff oil and shock oils
have to stop after my hand startin to hurt from metacarpal fractured.
thanks. thats d plan 🙂
d plan for now is to rebuild. have to complete d truck then add few mods.
finally finish her up yesterday
went ahead and get a lrp .30 and ofna 086 exhaust
body should be fine for now but def gettin a new 1 when this body get beat
thanks all
yes I'm lovin d lrp right now. has so much torque cant imagine hows d new .32 will be. i used to have picco p3 .28 at my kyosho inferno gt2 and i lovin that engine also. d lrp for d $$$ you cant beat it. I'm goin to get lrp .28 and puttin that to my kyosho inferno gt2 🙂
got some new items
replAcin my steerin servo w/ this
integy hubs, xl diff, shaft etc
