wicked i love this idea i think i will try and make something like it also if u want 2 bend something and u don't want it to fold ova u fill it with sand heat it then bend and it will b fine
hmmmm...this thread is about making the roll cage out of delrin rod...so the "sand filling idea" (while it works well with metal tubing) really doesn't help with the delrin...
actually, to prevent the same defects in the delrin/acetal rod, you could try finding some coiled spring with an I.D. the same diameter as the O.D. of the delrin...slip it over the area being heated and bent (as long as you don't melt the delrin)...the spring should help to maintain the roundness...same sort of idea, except dealing with the O.D. instead of the I.D.
Is it Ok to post another "How To" on my custom roll cage build? What I was planning is show you guys how I built mine and then build one of those fold-able ramps someone posted up here (by xtremesavvy) and start bashing the heck out of it and see where the weak links are...do some R&D this way.
