Here is my .02
I run these pipes on a rb mod sts d30m, a stock sts d30m, and a K5.9.
I would like to see the pipes maybe hard coated black, come with a set of couplers of different length (to tune with the different sizes...ie low/mid/top end--easy to switch out) and a rolled edge to the pipe to help the grip with the coupler setup, or a full-on one piece design with 3 headers in a kit (now this would be a pricey option but worth it imo!) NOTE---the one coupler setup is still "tuneable"---you slide the pipe closer or farther away from the header for the desired performance.
Now with the stinger I like useing the silicon deflctor...now I would like to see it as a "built in" design as long as there are no clearence issues ( the silicon deflector bends, which is nice for those hardcore bashers that get a little wreckless and won't ruin the pipe with a hardcore crash.)
I love the straight pass through design (and the exhaust noise/tone) and would like it to stay the same, best imo! I find the smoke blowing over the top/side of the truck easier to tune with (very quick to see if your lean or rich) as it does not "mix" with the rooster tails/dust that the truck kicks up while running. (I'm in dusty Texas so this helps!) As a side note maybe a little less noise for the guys that run in the city (but not a must have....original is best imo!)....keep your neighbors happy...lol!
I would also like to see a Macspro 90 degree block style pressure fitting to be used also like I have used in my pipe build (I will link it at the end of this post). I have found it to be a clean look and very strong and a great way to manage/angle your line away from possible areas that can damage the pressure line.
Now for mounting...I have built 2 of these pipes with Robins advice, and I used the macspro mounting kit for planes. If you run a mid tank like me it is very easy to use. Now I would like to move the mount more to the rear of the pipe closer to the coupler as that is where I have seen the most flex in the pipe since it is so long. Maybe make it a 2 mount system...stronger...one mount close to the coupler (which you could use a prexisting hole in the stock/aftermarket tvps and the Macspro plane mount and a zip tie) and one at the stinger side with a welded on bracket utilizeing the stock hanger system allready installed on the truck from the hpi factory.
So a full on kit with mounts, header, coupler, and pipe....I would pay $80-95 depending on finish. You can use the stock savage header for a price saveings...maybe $55-65 with no header depening on finish.
A full kit with 3 different size couplers (as mentioned above), zip ties, header, pipe, and mounts....I would pay $85-100 depending on finish.
A full "tuneable kit" with 3 headers with silicone gasket and springs, one piece design, mounts, and pipe....I would pay up to $130-145 depending on finish.
Ohh yeah and don't forget the Macspro/Extreme Rc Mod stickers in the packages...gotta show off where we got them from!
The link to my pipe build.....
https://www.hpisavageforum.com/forums/showthread.php?t=8629
