Hi, The pull start on my Savage has broken and I can't find a replacement anywhere. Part no. 15226. 11mm hex. I can only find ones with a larger hex. I'm in the U.K. Anyone know where I can find one or have an alternative solution? Thanks.
i having same issue, how did u resolve issue..Hi, The pull start on my Savage has broken and I can't find a replacement anywhere. Part no. 15226. 11mm hex. I can only find ones with a larger hex. I'm in the U.K. Anyone know where I can find one or have an alternative solution? Thanks.
https://rcscrapyard.com/pull-starts...start-kit-unbreakable-cord-12mm-starter-shaft i contacted this company and waiting for stock.i having same issue, how did u resolve issue..
https://wheelspinmodels.co.uk/i/75169/The K series engines use an 11mm hex starter shaft and trying to find a pull start or roto start to fit these mills is now on impossible. I have 6 of these K mills and have found that the starter shaft from an SH.2.8 or Dynamite .26/.28 can be used as a replacement. These shafts are 12mm and not 11mm so will allow you to use any 12mm pull/roto start.
I was buying them from RC Scrapyard but didn't know what engine they came from, so I asked the question and Jam1 came up with the answer. Have now found that Wheelspin Models stock them.
