k4.6 factory needle settings
Thread starter #1
Derek_2694
Likes
0
well today i went to bash my truck out in the backyard and i noticed that the truck wasnt preforming right.so i went to adjust the high speed needle to lean it out because it was running too rich, when i noticed that my mid range needle backed out a lot. i don't know the factory setting of it to work from either. i also was wondering if my low speed needle has done the same thing so i also need the factory setting for that. thanks if anyone can help
derek
https://www.hpisavageforum.com/threads/nitro-engine-factory-settings.11154/
AllanQ
Likes
0
St. Marys, Ga
k4.6 factory needles settings are:
HSN - flush with the line scribed on the brass barrel
MSN - flush with the carb body. I turn mine in about a half turn from flush.
LSN - flush with the housing.
the MSN on these motors like to walk. A little dab of rtv or something to hold it in place is what I recommend.
Thread starter #3
Derek_2694
Likes
0
thanks allan. yea the MSN looked like it was about to fall out. it was out about 1/8 inch. ive only taken out the LSN and the HSN to change the o rings in it.
Shaun
Likes
0
Canada
i've always wondered why the mid range seems to like to back itself out when the hsn or lsn doesnt seem to do it?
Thread starter #5
Derek_2694
Likes
0
mabey the o rings aren't giving it a snug enough fit
Likes
0
I sealed mine off at the same time I sealed my k4.6. It did the same thing a couple times and that was a couple times too much for me
AllanQ
Likes
0
St. Marys, Ga
Clement could answer those questions better than I can. He still has the motor and would know the difference, if any, between the two.
