K 5.9 carburetor o-rings
TheBlueTree
I've been trying to find replacement O-rings for my K 5.9 engine carburetor without success. Is there a commonly sold kit that is compatible with the K 5.9 engine or a place to buy the o-rings in general? I emailed HPI and they clarified that the O-rings I need are:
1: 15235 O-RING 22.0x0.9mm – Backplate
2 : 15270 O-RING 11.5x1.25mm – Carb Throat
2 : 15278 O-RING 2.0x1.5mm – Low Speed Needle
3 : 15279 O-RING 2.0x1.7mm – Idle Screw, Mid Range Needle Outer, High Speed Needle.
1 : 15284 O-RING 2.0x1.0mm – Mid Range needle Inner
I also live in Canada if that helps. Thank you so much!
