Integy aluminum diff casing for HPI Savage XS
NitroNation
Mister QUESTION with no SEARCHIES
i am running my Savage XS on 3s batteries and as a result i see a lot of differential cases getting busted because maybe they get too hot. the centre transmission casing also damaged therefore resulted in bigger damange because bearing not able to hold shafts and gears in place. i am considering switching 2 differential cases to integy aluminum and the center transmission case also to integy aluminum...
what do you guys advise ...??
The center I'm not sure about. The other for the diffs, I'd advise against it. 1- your gonna lose the easy access to the diffs. 2- I ran alum diff housings on the full size nitro and it tore the diffs up real bad.
I thought you were talking about the diff cases and not the housings. Stop runnin 3s and you'll save on parts.
most of my problems are coming from the middle actually... the tranny housing can't take 3s... i think i might get the tranny housing only and not diff housing... thanks for the advice..
