inline throttle servo w/ innovative r/c tvps?
carnage79
nashville,tn.
i am wanting to do the inline throttle servo w/ my innovative r/c standard lcg tvps. i've seen a couple of savvys on here w/ this setup. how do i do this? and what parts will i need w/ these tvps to make it happen? JT, if you're reading this i like that aluminum linkage piece for the carb u put on your anger management project truck. do i need anything to make that work w/ mine other then what comes w/ it? can i use my stock gas tank to go where the radio box is?
The aluminum STS linkage works nicely, might have a slight issue on the standard lcg tvp's though (not certain), as for the stock tank moved to the radio box location there is a few people that have done it. I think [hs] darkshine used the stock tank in radio box location.
I use RPM, Traxxas, Kyosho servo mounts or you can even make your own. I used RPM for that particular build.
FLM also makes servo mounts. They even given you the option , silver or black.
