Idling Problem
wagn
I'm having a problem with my Savage that i can't figure out. The throttle trim on the controller moves the servo arm but there's no response from the engine idle. I've messed with the servo arm tryin to reset it and i think i got it wrong, or the engine tunning is outta whack, oooorr there's somethin wrong and it won't tune. It's really startin to bug me, so bad i'm ready to take it into the shop and let them fix it but that wouldn't b good.Thx
Could be a tune issue, it's easy enough to re-set the needles and see if that's the case. Might also be an air leak...
Take off the Air filter and see what the slide does when you pull the throttle. Make sure you have a 1mm or slightly larger gap with full brakes and its wide open with full throttle. If not its linkage/servo/end points. If so then do what judge said and start over.
