MTBikerTim
Brushless Power!!!
- Australia
I took my savage racing on the weekend. It was great fun. I learnt that I can't drive even though I kind of knew this already. I also learnt that my truck is set up horribly for racing. The track is fairly tight and I was having all sorts of trouble staying on the track. First race went well and I some how ended up in first. Second race I started late due to blowing a new glow plug (which worries me) and then I only made 1 lap before I broke a rear drive shaft. Third race and first of the finals I started OK got into first by blocking and running other people off the track and then crashed and moved to the fitting place of last. I then decided to plow into the pit box halfway down the main straight. Being a savage everything seemed OK until I went over the first jump and the spring feel out of one of the front shocks. I had broken a shock shaft (stupid unreliable losi parts).
Overall it was quite a fun day. I definitely need to change the suspension setup. I think some new wheels are in order. Thicker oil in the front to pull it around corners better. Probably most of all I think I need to gear it up a bit. I had far too much torque. With the nova clutch shoes and running 15 49 it wants to wheel stand constantly which makes it really hard to go around corners.
Any suggestions on what weight oil for the front diff? Remembering this is a fairly tight track any other recommendations.
