i stripped another clutch bell
adb140275
aka Ebee
its a robinson one this time... i stripped it on an hpi steel spur. whose bell can stand up to the hpi steel spur? i had my mesh set right, i don't know if the motor moved, but regardless, i need a better cb. whose can i buy that wont strip off?
I am worried about the same thing. I kuat out a steel spur on my truck but I have a fioroni clutch so I can't use the hpi CB as it is not deep enough.
Be sure that the CB is lined up straight with the spur gear, I have also destroyed more Cb's and spur gears than I care to admit. My biggest problems were crooked alignment and bad mesh, a close third was loose mount screws and cracked engine plate. Good luck
