HPI finally made sway bars?!
Hypnotiq
I - AM - HYPNOTIQ
Lake in the hills, IL
HPI said:
#102538 SWAY BAR SET (FRONT/REAR/SAVAGE X)
Savage truck owners can now add a Sway Bar Set to their trucks. This is an official HPI option part that is built to factory specifications for a perfect fit. Each set includes a pair of 2.0mm black bars (medium stiffness) and a pair of 2.4mm silver bars (firm stiffness). The design is fully adjustable so you can easily vary the stiffness to tune for track conditions. A middle notch keeps the sway bars centered and prevents them from sliding. All of the necessary mounting hardware is included. Fits all Savage X trucks. Also fits original Savage trucks that have been upgraded with Savage X bulkheads.
2538 SWAY BAR SET (FRONT/REAR/SAVAGE X) $28.00
I know people have been making there own for some time now but HPI is just finally releasing them. Tried to google the part number and can't find a place to buy them yet.
(useful information removed)
I knew those where coming out but i fugured i wasnt going to say anything.
You might want to watch for a new ss coming out
HPI OCT RELEASES said:
SAVAGE X SS K5.9 KIT W/ NITRO GT-2 TRUCK BODY
The Savage X SS is now available with the huge K5.9 engine. The powerful Nitro Star K5.9 engine comes from the Savage XL truck where it has proven to deliver massive power, bolting it into a smaller and lighter truck means it will have an even higher horsepower-to-weight ratio! The KAn anodized billet aluminum head keeps it cool during extreme off-road driving, and standard features include true ABC construction using a long-life chromed sleeve, a composite carburetor for high performance and improved high temperature tuning, and a pullstarter for easy starting. The engine is mated to a high performance polished tuned pipe and high flow tube header to help maximize power output.
The drivetrain is equipped to handle the K5.9 power. Critical parts from extra-tough Savage Flux drivetrain have been added, including #86246 Super Heavy Duty Drive Shafts, #86928 Super Heavy Duty Axles, #86248 Super Heavy Duty Diff Shafts, and #102692 Machined Bulletproof Diff Bevel Gear Set. Cast alloy differential cups with steel pin guides are standard on the front and rear of the truck, delivering unmatched durability and extending the standard maintenance interval of the diffs. All of the internal diff gears are shimmed for precise mesh, and we even shim the outdrive bearings and input shafts for extra precision. And, we include a hardened steel spur gear with a matching ventilated "racing" clutchbell for the ultimate in drivetrain strength, right out of the box.
Following the tradition of past SS models, the Savage X SS is one of the few build-it-yourself monster truck kits on the market, aimed at R/C enthusiasts who enjoy the process of building and customizing their truck. Standard equipment includes the powerful K5.9 (5.9cc/.36 cubic inch) engine with pullstarter, clear body, along with an exciting list of new features and updates that make the Savage X SS capable of handling the toughest beating you can throw at it.
Nitro Star K5.9 Engine
High torque K5.9 engine delivers massive power.
Clear Nitro GT-2 Body
Supplied with a clear body so you can add your own custom paint job. Window masks and pre-cut decals are included.
High Performance Polished Tuned Pipe
Dual chamber design for higher top speed and wide power band.
Dirt Bonz Tires
40% lighter than the GT Truck Tires for more speed, soft and sticky S-compound rubber for high traction on dirt surfaces.
Front and Rear Skidplate Bumpers
Realistic skidplate bumpers made of high impact nylon look great and minimize crash damage.
Cam Type Servo Saver
Adjustable design allows precise tuning for optimal steering response and extra servo gear protection.
Dual Disc Brake
Stainless steel, drilled disc brakes provide serious stopping power, enough to do "brakies" on command.
4-Gear Differentials
For increased drivetrain durability as well as extended time between maintenance.
Super Heavy Duty Diff Shafts and Cup Joints
Hardened for extra strength and to lengthen the time between re-builds.
Super Heavy Duty Dogbones
A powerful engine requires a heavy duty drivetrain for durability. We've got you covered with heavy duty dogbones, diff shafts and cup joints.
2 Speed!
Adjustable 2 speed transmission with heavy-duty metal internal gears for durability, bottom end punch and high top speed. Adjustable slipper clutch for drivetrain protection.
Adjustable Upper Arms
Turnbuckles allow easy adjustability of the suspension geometry for improved handling and performance.
Easy Maintenance!
Quick access to the front or rear differential by removing six screws.
Redesigned Radio Box
New radio box with extra room for electronics, includes provisions for an external battery level indicator and an optional charging jack. Easy-to-use design eliminates the need for clips.
Easier To Work On!
The center gearbox can be accessed without removing the chassis plates. Just remove six screws and the top case lifts off for quick and easy transmission maintenance.
Low CG TVP chassis
The new chassis design lowers the center of gravity for stable handling and faster lap times.
Lightweight suspension arms
New lightweight suspension arms deliver quick suspension response and reduce overall truck weight.
More Adjustability
Adjustable turnbuckles allow you to make quick and easy suspension adjustments. New shock towers have three different shock mounting positions for a variety of suspension setups.
Chrome Warlock wheels with tough 17mm hex hubs
Large 17mm metal alloy hex hubs hold the wheels securely and prevent stripping.
Fully Compatible
Compatible with most existing Savage option parts.
Machined Head
Billet aluminum heat sink for better cooling and durability. Machined cut-outs for convenient access to mounting screws for easy disassembly.
Durable Finned Aluminum Crankcase
Cast aluminum crankcase is designed for maximum durability and heat dissipation with numerous heat sink fins.
Heavy Duty 3 Shoe Clutch System
The 3 shoe clutch system paired with the massive K5.9 engine gives you the power to do wheelies on command!
ABC Construction
The K5.9 engine features true ABC (Aluminum, Brass, & Chrome) construction - the ultimate in strength, durability, and high performance.
Innovative Dual Stage Air Filter Design
The "High Flow" Dual Stage Air Filter dramatically reduces intake restriction as it smoothes and straightens air flow. More air means more usable power and acceleration throughout the engine's rpm range. The innovative design also offers unprecedented protection from dirt and dust.
#104284 SAVAGE X SS K5.9 KIT W/ NITRO GT-2 TRUCK BODY $949.00
Great find, il look out for them when theyre available and that new SS looks awesome (except for the K5.9 and stainless brakes) suppose they had to leave something left to upgrade lol
looks interesting wondering how well they will work. I made my own a month ago out of the lst kit for 18 bucks. I think 28 is a bit steep but hey that is what the hpi site says and the site prices are always higher than actual retail.
It was working a while ago but the page was pulled down for some reason.
It seems great, I am gonna get one set as soon as possible. I live in Turkey, i went to the HPI distributor today and ordered a set of this sway bars, they said it can take 3 or 4 weeks to arrive. I share the pictures after i got it.
I am not sure about them mounting in the front like that. My Mini-raminator had sway bars like that and it seems to really make it to stiff in handling. Guess I will wait and see how they work after their release.
3 to 4 weeks? :crazy: YIKES! Yeah LHS said they can't even order them yet.
that savage XL SS kit doesnt even come with big bores for that price! /FAIL
Agreed, I'm tired of HPI releasing the savage with only minor upgrades. They need to step it up and start making some real advancements.
While I agree some "goodies" should have been added, I am just happy to see HPI release a KIT!!! (I've been personally on them about that)
The mags will have you believing that RTR's are the wave of the future, and I think the manufacturers are listening to that nonsense.
They are cutting out a HUGE segment of the hobby. I, and many others LIKE TO BUILD KITS!!
I don't think youl be able to use it with RPM arms as they are, youl need to drill the hole thats in the stock arms.
