HPI Blitz lightweight aluminum slipper carrier set + more
Hypnotiq
I - AM - HYPNOTIQ
Lake in the hills, IL
attachment.php
This light weight aluminum slipper carrier set is a high performance option part for HPI BLITZ trucks. It's precision milled from aluminum for decreased rotating mass and quicker throttle response, and finished with HPI logos on dark brown anodized aluminum to match the latest BLITZ option parts. This set replaces stock slipper components on BLITZ trucks, and can be used on E-Firestorm trucks that use the #104137 Titanium Top Shaft or #103375 Top Shaft.
#104136 LIGHT WEIGHT ALUMINUM SLIPPER CARRIER SET $12.00
attachment.php
HPI_FEB said:
Blitz Titanium Top Shaft
Upgrade your HPI BLITZ truck with this Titanium Top Shaft for the transmission. This part replaces the stock steel shaft with a high-tech titanium shaft, precision machined from strong and lightweight aerospace titanium for less rotating mass and quicker throttle response. This is a bolt-on high performance option part for BLITZ trucks, and E-Firestorm owners can use this with #103377 slipper clutch set or #104136 light weight aluminum slipper carrier set.
#104137 TITANIUM TOP SHAFT 5x48mm $22.00
attachment.php
HPI_FEB said:
Blitz Titanium Gear Shaft
Upgrade your HPI BLITZ truck with this Titanium Gear Shaft for the transmission. This part replaces the stock steel shaft with a high-tech titanium shaft, precision machined from strong and lightweight aerospace titanium for less rotating mass and quicker throttle response. This is a bolt-on high performance option part for BLITZ and E-Firestorm trucks.
#104138 TITANIUM IDLER GEAR SHAFT 5x16mm $11.00
