HPI 4.6 v2 Engine Starter Spring and Pin
It’s not miss packed it’s a spelling error it’s correct part number but wrong description add same problem 👍👊
Take it you’ve got the new all steel 3 speed gears ? There more shimms on the new centre cluster old 3 speed add 1 shim new 1 as 3 shimms + 1 on end in front of bearing 👍👊
It is all HD now - originally sourced a center gear box with all the gubbins - the first gear is/was plastic - instead of going all FLM - went first gear HD and then upgraded what I thought was to the 2nd HD - which actually turned out to be the 3rrd HD Faster Top End gear.
Just waiting for the adjustable HD 2nd gear to come in the mail - appreciated the shimming tips!
👍ye Hpi do the steel 1st gear now as well ye 3rd gear actually says 2nd gear on parts bag but it’s correct part number check the pics above I sent you Hpi done few typo mistakes on the new 3 speed stuff were are you based are you in the UK ? 👍
