SwatKat
I have just put a new set of HPI aluminium threaded shocks with 30wt oil.
I read trhe instruction sheet and there it said, viewing the pics: fill up with oil until 4-5mm, move the shaft up/down to remove oil and then fill up with oil all the way up until it's full. Then put the cap and a little oil should come off through the small hole in the cap.
Now is this correct or I overfilled the shocks? I ran them for 3 times but not hard stuff and I was wondering what's your oppinion?
W/o the spring, If the shaft moves back a little, is's ok?
Thanks.
Thanks.
