Please help I have searched forums and manuals but I am just not seeing exactly how to remove the carb. I know there is a Lock Pin, but how does it work? i have removed the screw that is in the lock pin but I don't know what else to do to get the carb off. Thanks
you just loosen the screw on the side of the crankcase that holds the carb in and either grab and give it a little twist and pull or if it is stuck in there and the screw on the side of the crankcase is loose then get a tap and a hammer and lightley tap till it starts to loosen up and move from side to side then pull it out
loosen the screw several turns and tap the screw first. it has a pinch system,
kind if like the goose neck on a bike, then you can gently twist the carb out.
