Hole shot tire foam inserts...
luke1983
Germany
I ordered 4 hole shot tires, they came in two packs of two. One set has different size foam inserts to the other set. I found this out as i took the foam out to check it as it was pushing the tire side walls out loads and the inserts in one set are atleast 5mm wider than the ones in the other.
I'm confused to be honest. Are all the tire inserts the same for the same tires as you would expect? Are they different for different hardness?
Any help would be greatly appreciated and i'm sorry if my post is a bit garbled!
Whilst i'm in this forum does anybody know if you can get any ribbed tyres for standard sized wheels please?
