Where do you get this red chassis grease link pleaseYou need a certain amount of oil to get proper lubrication to the engine... I use Morgan Sidewinder basher blend 20% with 16% oil and have zero problems with too much oil on anything.....
take the OWB out. clean it inside and outside with some denatured alcohol, do not use any type carb or brake cleaner on it... these will melt the plastic cage...
Once it is all cleaned up and dry, apply some Red Chassis grease for 1/1 cars to the rollers inside, lightly coat the shaft with the same grease and put it back together.... doing this will help it grip better and keep some of the excess oil off the bearing.....
Thanks would you mind helping me out because I need to know if my engine is a k or a f series here is a picture of it
