help with 23mm adaptors to fit savage x
boaty1
cedar rapids iowa
I just bought a set of Big joes on rims and they have the 23mm hexes. I have a set of adaptors but they wont fit over the axle stub on the savage x. Even if they did, the savage wheel nuts on the x have the bigger flange. Where can I get some adaptors that will work for the X?
which adapters do you have? i just got a set of dynamite's from souja55 & they fit rite over the X & XL.
cant use the flange wheel nut tho, you need the unflanged that you can get at your lhs
Sounds like you may have 23mm adapters for a t-maxx. I had the same problem and ended up buying another set of pro-line 23mm adapters for a savage which fit just fine. I am not using them anymore and they are just collecting dust in my parts box. PM me if you want them.
