Help me diagnoise this issue...
Hypnotiq
I - AM - HYPNOTIQ
Lake in the hills, IL
Was ripping around the parking lot.. everything was going PERFECT. Towards the end i was drifting around this turn and side swiped this curb. Hit it hard enough i knocked the rear turnbuckle out. After about 4 passes at WOT i started the notice the rear wasn't gripping.. it was only pulling from the front. I picked it up off the ground and hit the throttle only the fronts turned. No rear spin at all. I opened the rear diffs and i honestly see nothing wrong. What else could stop these from spinning in the rear only?
make sure the set screw to the break hub and to the rear is there and tight . also make sure you didnt blow anything else on the rear driveline
+1 on the 10K - I have 30k in my basher and 10k in my other one - the other one is great in the parking lot, lot better traction, etc.
Hope this helps!
Bob
I would go thicker in the diffs, driving on-road has more of a tendency to lift the tires, if the fluid is light the diffs will unload too easy. I'd go 30 rear 50 front for weight.
He has 6 trucks lol, I really don't remember what he's got in that one, I will be talking with him and I'll let you know later. Gotta go pick up his new 5t, he's in the bush working.
