Glow Plug
Sccar
Earth
Just changed the piston and con rod in my engine, it run great but burns out the glow plug. I used 3 glow plugs in less than 10 minutes. What can I do to correct that?
Thank you
What % fuel are you usin and what heat range plug? Also, leavin the igniter on for too long of a period will fowl out a plug real quick. Also could be due to the way the motor is tuned. Start at factory settings and go from there.
I am running 20% fuel and, I burnt out a 3 med plugs. 1 odonnell 100 and the other 2 not sure the brand.
I did not break the engine in after I changed the rod and piston. I will try that.
Thank you
