gearing question
NITROMITE
Pataskala,Ohio
i am on the hunt to replace my clutch, clutch bell, spur, the whole nine yards.
right now i have been running the axial .28 with the stock clutch set up from the old .21 and gear (15T) the spur i have been runing is (49T) now I'm not good with gearing but i like this combo. i tried a 47T spur and was dissapointed.
i guess what i need to know is, what do i need to buy as far as the flywheel clutch and gearing to keep it as close to what i had but make it alittle better (a bit quicker off the line would be nice but i don't want a wheely king) thanks for any help
What i need to buy
Dynamite Max - Life Clutch shoes $24.00
Mugen 1.0MM Springs $4.00
Robinson Racing 14T CB $19.00
HPI X 49T spur $4.00
i was looking in there for him.. couldn't find the actual chart though
Copy / Pasted off another site..
Code:
SPUR	CLUTCH	RATIO
49	18	2.722	SS opt
50	18	2.778
49	17	2.882
52	18	2.889	Doesn't fit w/o mods
50	17	2.941
52	17	3.059
49	16	3.063
50	16	3.125
52	16	3.250
49	15	3.267	SS orig
50	15	3.333
52	15	3.467
49	14	3.500
50	14	3.571
52	14	3.714	21 stock
49	13	3.769
50	13	3.846
52	13	4.000
49	12	4.083
50	12	4.167
52	12	4.333
So I'm running 3.267 with the 15/49 set up
what about the 16/52 thats 3.250
what would the difference be faster on the low end? i know its close but that is the sweet spot I'm trying to sytay arround.
other question is about the cluthch
any suggestions?
The larger the number = more torque and lower speeds
The lower the number = less torque and higher speeds
Now this does not factor in tires, if you are running large tires you will need more torque.
Good luck and hope this helped
49/14 3.500 so i would probebley like this for alittle more takeoff would this kill my top end? i was @ a 3.267
and what about the clutch I'm still rumming stock
It all depends on what you want, more speed or more snap off the line. CB/SG is just one factor, there are different clutch materials and spring weights that all have to be considered.
You might want to consider the 3 speed tranny with the high speed 3rd if you are looking for the best of both worlds.
Me personally I have been very happy with the performance of the stock clutch and gearing in my 4.6SS racer @ 47/17 with LPR Crime Fighters for a Truggy and 6MM extended LCG race TVP's. It is very stable and does not wheely on the track. I can get it to wheely on the pavement though.
i just want a good clutch and good gearing like i said before i want to keep it close to the 15/49 gears but i would like alittle more off the line without killing alot of top end. say i stick with the 15/49 gears is their a better clutch i can get for better takeoff? the clutch I'm running is stock
I'm rumming pretty low profile dirtbones i think i have the gearing figured out now what flywheel and clutch/springs like i said I'm still running stock
I'm running the 16/52 combo in my XL with the terra-pinn tires and I like it. Now that the 5.9 is running good it is a wheely machine and to me it hauls on the straights still. I'd say I'm getting at least forty mph by the looks of it. Not as fast as many guys here are, but the only time I can get it that fast for any length of time is running it up and down a straight paved street anyway lol. Bottom end is killer now, and running 225-245 degrees depending on airflow and tank level. Have to learn how to balance on that HPI wheeie bar though. It's kinda tough to get it right. You can get it to do some pretty long wheel stands though. BTW I'm running the Dynamite Max-Life clutch shoes and they hit pretty hard. It looks faster than forty but I know with my gearing it's not really that likely to go more than 42 or 43, I think I read that somewhere.
Dynamite Max-Life clutch shoes? anyone else tried these?? not to doubt ya mike just need the good
I know quite a few others here use, or used to use, them before getting something else like the fiorini (sp?) clutch setup. I like them a lot, so far they seem to grab better than the HPI aluminum shoes. They have a rough texture which seems like it would be better than the smooth HPI ones. That roughness may just be a coating though. I have not inspected them yet since putting them in, but my XL wheelies like a champ now and I tried and tried before but couldn't get it to wheelie.
ygpm nitromite!!
Hey i forgot to mention you'll need Mugen 1.0mm springs!! SMF has them for cheap!
I run the following..
Robinson Racing 17T CB $19.00
I love it man.. I had a RR steel spur as well but it stripped on me.. Waiting on a email back from them now.
ygpm nitromite!!
are these LHS prices if so i can get them cheaper on fleebay but thanks for posting the prices
I thought I would mention that I did use my stock HPI springs from the k5.9 with the DYN5180 shoes. They did not lock in as tightly as with the HPI shoes because of a slightly different angle but I have been running them for almost a gallon with no problems.
I noticed a difference when i put the mugens on. More responsive.
