Gear ratio help needed pls
bashn4fun
i'm going to be running an LRP .28 with a BUKU pipe and i have a bit of aluminum so the truck is heavy. i'm also planning on 7.5" Genesis wheels/tires.
with that said, what CB/SG would you guys recommend if i want mostly torque and low end power? i know the wheels change things quite a bit since they're huge. i still want to be able to do wheelies and have plenty of grunt. how about 14/50? 13/50?
thanks!
W/ the lrp .. And your truck, I would run 49/17..
I ran the same set up and ran 47/20 Still would wheelie !!!
13/50 ???
They don't even make a 50 tooth spur do they ?
Anyway that combo would really suck !!! go w/49/17
thanks for the responses guys.
yes, i have a steel 50 spur now and don't want to replace it. so what pinion you think? 17 won't be too tall??? with those wheels it seems like that would be really tall. but if you've done it then you know better than i would!
