FX's Savage Rebuild
Sorry. I was reading through threads and when I was in the next room my son hit some keys and it sent a message. I edited it and was trying to explain. Guess I should have been more clear.
no problem i did not mean to sound like an a$$ i was just wondering . Sorry for coming across like that.
lol no problem oregon.
I just realized I put the center skid plate on backwards, I just fixed it. The X is supposed to be at the front.
Nothing better than filling your online shopping cart right! Nothing worse than having to pay for it either!
Here is what I have ordered, after that there are still more things but this is it for now.
HPI 3-Pin Flywheel
HPI Savage/Hellfire Diff Case Gaskets, 6pc
HPI Savage 4-Gear Diff Conversion Set - #87193 HPI Savage 4-Gear Diff Conversion Set
HPI Savage Bevel Gear - 43-tooth
SMF High-Strength Hex-Drive HW Kit for HPI Savage
Mugen 1.0mm Clutch Springs
HPI Savage 160cc Primerless Fuel Tank
For the front diff-Mugen 7,000wt Silicone Diff Lube
For the rear diff-Mugen 10,000wt Silicone Diff Lube
I know, i know. YAWN! Show us some good stuff FX, well it'll get here eventually, until then be this is what I got for ya.
A tiny update I received my Lunsford Titanium Turnbuckles. They did come with the plastic end pieces but I used mine anyway. If you know anything about me by now you would know that there is no way that I would drop 40 bucks on these. I picked them up for 11.50, score! Snapped up a few pictures.
I received my small parts and will place my order on SMF for the engine and bulkheads. Still haven't figured out the tire/wheel combo so if anyone would like to suggest tires, wheels, etc. it's more than welcome. I am looking for something that is good for racing and bashing and something I can use on the road too.
Here's some pictures of some small things I've order. I know you guys must be tired of not having any pictures of cool stuff, sorry they will be here soon.
quick sugestion, with the tie rods, i found that the plastic ends after a few months racing began to give way ALOT. there was alot of slop and made getting the truck setup correct very difficult. I would reccomend gettin alloy ends instead
tyres for racing and bashing, I'm very very impressed at the with my Hong Nor predators. They suit alot of surfaces and give more grip than a brickpin style tyre.
either that or you cant go wrong with a standard tread pattern for all round use. as they say 'good at everything, best at nothing'
Tie rods? Are those the plastic pieces on the ends of the turnbuckles? If so where could I get alloy ends?
i got some alloy ends for the turnbuckles off ebay. think they were gpm or similar
bowties wont last long if you run them on the road. plus in the wet they just slide (which can be fun too)
I ordered my parts, so I guess I can finally run my truck. Can I get a hell ya!?
Products
2 x HPI Savage X Gear Box/Bulkhead Set - #85235 (HPI85235) = $25.98
1 x Axial .28 Spec 1s Big-Block Engine, Gray Head - #002 (AXI002) = $124.99
1 x Pro-Line Premium Blend CA, Thick - #600601 (PRO600601) = $8.49
1 x HPI Savage Bevel Gear - 13-tooth - #86031 (HPI86031) = $8.99
1 x Hitec On/Off Switch with Charge Jack - #57215S (HRC57215S) = $8.99
3 x HPI Savage & MT2 49-Tooth Spur Gear - #76939 (hpi76939) = $8.97
2 x HPI Savage & MT2 Slipper Clutch Pad - 2pc - #72131 (HPI72131) = $6.98
1 x HPI Savage Cam-Type Servo Saver Set - #87197 (hpi87197) = $15.99
1 x FLM Steering Link for Savage - #48000 (FLM48000) = $6.99
1 x HPI Savage Wheelie Bar Set - #85245 (HPI85245) = $16.99
4 x 10x16x5mm Rubber-Sealed Bearing - 1pc (AVI101605R) = $3.96
Sub-Total: $237.32
United States Postal Service (1 x 3.6225lbs) (Priority (2 - 3 Days)): $10.00
Total: $247.32
This build is not over, not by a long shot.:smiliejam: :smiliejam: :smiliejam:
Nice list FX. Let me know what you think of the FLM steering link. Not real crazy about the integy one I have. I just went thru your list of stuff. You have it going for ya. Real nice setup bud
Untill he receives his credit card bills..
Really though, nice truck, cant wait to see the outcome.
[hs] darkshine;17760 said:
cool!!!
plan on stripping some sg's??!! :¬p
Nah as long as it's meshed right I'll pray to the RC gods that no stripping occurs. If the RC gods don't listen I'll use my RR Steel Spur.
[hs] darkshine;17762 said:
the only reason i said was you had a few spurs and slipper pads in one of the pics...
Right O, you can never be too prepared.
