- Worthington, MN
Hey guys what seals the front of the engine? Is it the bearing or is it something else?
To my understanding fuel/oil will seap to the front bearing which lubracates it. There is a hole up there which runs up by the carb in the crankcase which the carb creats vacume that is supposed to suck the excess fuel/oil back into the engine threw the hole. This hole can get clogged and then will let oil seap past the front bearing.
Again this is why they recomend front bearin replacement because if that is worn and has slop it will sear the sealing part out of the block then there is no more or very little seal left which then the engine will leak all the time or worse than usual.
