Flysky FS-GT3C 2 noob questions..
baris41
Hey guys, today i bought a fs gt3c and I'm quite happy with it. Though i got a couple of question with it.
First may i bind more than 1 flysky receiver to the transmitter? Does the model select option indicates different receivers?
My other question is about throttle trim. On the first try after binding, front and rear trim option was in the middle (normal) but on the second attempt the car doesn't move backwards do i needed to adjust it to B30. What might cause that.
Thank you.
Yes the model select option indicates different receivers.
And you might need to calibrate the ESC. You can find how from the instruction of the ESC.
