Flux Battery box?
Randy
Has anyone heard of a battery box conversion in witch you switch right and left battery boxes and this allows the lid to open all the way?
I hear you Randy! I came across something while searching through Google...sadly I didn't save the link. If I recall...someone flipped the battery boxes so the lids open outwards away from the frame....but also did some minor mods to allow mounting. I'll see if I can find that again...but a quick Google should find it as it is a niggle with the Flux and a Mod many have done I'm sure.
I have some friends just done away with the lid and use 2 wide velcro straps each box with some foam to shim if needed. It works anyway.
It's all handmade with 5 / 8 nylon rods bent using a heat gun. The wheels are HPI Goliath tires wrapped with 20lbs braided line.
Flux battery case are not in stock anywhere.. going to pic up Kershaw design battery boxes.. my 6C's have a nice snug fit..
