HopIt
Certified Nitro Addict
- Worcester, England
I just read your PM HopIt. You need the FLM drag link to get things all together. I just happen to have a pic of said part. It is the aluminum part between the towers. The part number is "FLM4800".
Also - while you have your truck apart, you should replace the 4 plastic bushings that the steering towers pivot on with ball bearings ... unless you've already done that mod. If you haven't done it, HPI has a kit with the bearings in it. However, the bearings are a common size. I just took the plastic bushings to my LHS and asked them to match it with a bearing. It is a good mod.
Thanks for that CRUSADER. My post actually contains a link to that part on the SMF web site, which Bruce should be packing up for me right now ! :Xfingers:
I did the sevo saver thing way back, and currently run the Hot Racing version, well most of it !
HopIt - in the pm you sent, you asked about the uprights that I used. I did use the HPI suspension upgrade kit ... well, most of the kit. I just de-anodized everything and then polished all the aluminum.
I don't like purple. There is NO purple goofy-ness happenin' on my SAVAGE.
How do you name a truck "SAVAGE" and then color every piece of aluminum (and some plastic parts) on the thing purple? Huh? How does that happen? Can someone 'splain that to me?
:bling: You do have a point ! It must have taken you a fair bit of time to make em shine like that ?It must be a european thing
I wouldn't know, I'm not European !
And isn't HPI an American company ?
