I'm actually looking at Odonnels webpage right now. It doesnt tell you what the oil percentage is. Does anyone have the link for the fuel thread on here?
I Know For A Fact That Blue Thunder Runs Hot!! I Bought 1 Quart Cuz Its All I Could Get And My Temps Shot Up Around 275 Or More Then Finally I Got Some Sidewinder Again And Temps Went Back To Normal Which Was Like 230 And i hadnt changed anything exept the fuel!
I would say take your engine apart and check the main and front bearings .. make sure they are spinning good and all the ball bearings are uniform
a bad bearing will cause high temps
OK and one more. This one is pretty interesting.
How do I read a glow plug?
It is easier to "read" the glow plug to determine if the engine is operating at full efficiency. It is usually possible to take out a new glow plug of an engine and look at it closely to see if the engine is running too rich, near full power, too lean, etc.
Follow these instructions to read a glow plug:
Using a new glow plug, install it in the engine you want to test. Make sure the wire of the plug is shiny and still new. Run the engine for a full tank of fuel at race speeds.
a) Engine running rich: wire and bottom of plug wet, wire shiny
b) Engine running at almost full efficiency: wire and bottom of plug mostly dry, wire slightly gray
c) Engine running at peak efficiency: wire and bottom of plug dry, wire gray
d) Engine too lean: wire and bottom of plug dry, wire out of shape (not coiled)
e) Engine FAR too lean, possible danger to engine!: wire and bottom of plug dry, wire broken or burned
Some glow plugs turn gray sooner than other plugs, watch out for this if you use plugs from different manufacturers. To test plugs (from your toolbox) you are unsure of, switch glow plugs after running a good plug. If there is no difference in performance, save the plug (put it in a plastic bag or box marked "Used Good Plugs").
