OK, I've been trying to get my F4.6 tuned for a few weeks now. I'm still not having much luck. When I finally got the engine running well (quick throttle response and nice top speed) the temp was around 300. I tried resetting everything and starting over. Still running hot. I decided to try sealing the engine today. I tested the temp again afterwards and its still hot. I can get the temp down but then the engine is running like garbage and bogging really bad. I have a steady flow of smoke at top speed but the temp is still too high.
Now I have two questions.
First is there anything else I'm missing thats causing this thing to run so hot?
Second is I saw a few places selling larger cooling heads for this engine. Does anyone know if they really make that much of a difference and do you think this would be the answer to my problem?
Thank you.
Thank you.
