ryanitro11
Had my .26 engine running mostly idiling and checked the temp with my temp gun and it was running around 302-306 degrees. I tried to richen it up but it gets sluggish. Plz let me know what I'm doing wrong!
true but you also want to be also dropping temps at idle. i believe its 1 degree for every 4 seconds, is what Robin from ERCM says..The vehicle sitting idle is not getting the air flow to cool the engine,since air flow is the cooling. Run it see how it does.Just my opinion!!Good Luck
