engine break in
twinengsav
Pa.
Hey all, I know this will be a dumb question but I here alot about break in from you all and most say it takes a gallon of fuel to break one in, I had never herd this till I came to this forum, I had went by the book and this was a long time ago but I had broke an engine in the same way with each, now I remember something about it taking around 3-5 tanks depending on the size of tank to fully break one in, so this is what I do each time I had to break one in, I had never had any problems doing it this way & even gotten 12-13 gallons out of my Hyper 8port till it finelly came apart, now after all that am I doing it wrong, if so what would you reckamend for me to do, maybe somone has a diagram or something along them lines on steps of a engine break in, so maybe things are different nowadays with engines and there proper break in if someone could help out here I would greatly appreshate it Thanks
STS motors took 1gal to properly break in.....HPI blocks, I usually did 6-7 tanks of heat cycling without issues.
STS was on this site for some time...it was recommended to have a 1gal break in for those....What kind of motor are you breaking in?
don't have one at this time, was just wondering about the 1 gallon breakin and what engins took the 1 gallon
Hey twin, it is just a handful of motors that require a gallon through them for break in. I know of three brands that take a gallon of fuel. The STS, Novarossi and RB Concepts. Every other motor I have dealt with only takes about 5 tanks before you start power tuning.
good deal & thanks for all the good info, as I had said before everyone here is great with all there help
Thanks to all
Engine Tempering & Engine Breakin
Reprinted From S-Grid with Stephen Bess's permission
If you are still idling at least a tank through during break-in, you're using the old-school accepted method (still works well for some!) but it's not the method that the top engine guys (Ron Paris, Dennis Richey, Rody Roem, Michael Salven are just a few I've spoken personally with about this) recommend anymore.
From the very 1st time you start your engine, plop the car on the ground & begin running it in a parking lot in 2-3 minute intervals, tuned only *slightly rich* getting the temps up in the 200F range on a normal day. Every 2-3 minutes, shut the engine down & let it cool completely with the piston at BDC, and then fire it back up; continue this cycle until you've run 15 min or so, and then bump up to 3-4 minute intervals. Vary the RPM and don't be afraid to get the temps in the 200's. What you want is heat cycling of the components without the incredible stress that comes with breaking an engine in when it's overly rich & cold. After cycling the engine in this manner for about 20-25 total minutes, it'll be ready for the track and race tuning. I realize this method goes against the old-school "idle on the box" routine, but you'll be amazed once you've completed this break-in routine, your engine will still have amazing pinch w/out sticking at the top AND your engine's compression will last far longer than it will with the "old school" method.
You say you run the engine at "factory settings" for the first FIVE tanks? That alone causes lots of stress, as the factory engine settings are very rich on every engine I've ever owned or tuned. The piston & sleeve haven't expanded to operating temps, and every time the engine turns over, the piston slams into the pinch zone at TDC. The not-so-surprising result can be a cracked con-rod at the crank pin--that's where the majority of the stresses occur as the engine turns over. I've only heard of about 6-8 engines breaking con-rods, and they're ALWAYS during the first gallon...and almost every time it's because the guys have performed the break-in procedure you described. Doesn't seem like a mystery as to why it's happening. Drawing out the break-in routine really stresses the engine & actually wears away compression along the way. This method I've outlined will feel weird at every step, but after you try it once, you'll notice a big difference in your engine's performance & lifespan.
Rick Brake RB Mods
Hope this helps; give this break-in method a shot--you have nothing to gain except longer life & more power
Use a MC 59 or the hottest plug you can get and burn 30% nitro. Keep your cool and be patient, It will come in to It’s own after about a gallon of fuel.
The tolerances are so far out because of the extreme modification that until it is broke in it will not act right. You will cuss the engine and me for selling it to you. So do not start turning needles to try to get it to run right, just enough to keep it running for as long as you can. Then when it starts to break in it will stay running longer and longer. Then one day you will praise the engine and me. Give it a good ½ - ¾ galloon and if you need us to break it in for you. William Copley my National drive does this for 45.00 – 55.00 and any questions as far as I can’t get it to run call William [email protected] Remember the engine is still not broke in until you have about 1 gallon through it so only make 1 hr on the clock adjustments.
