Hello Guys,
Need your help~
going to build a break in bench.
Below are the pillow back bearings and solid shaft stock.
Take a look and give your opinion, there are many choices of bearings and steel rod stock to choose from.
I want to keep it inexpensive. This will be made by parts available to all of us on the web. so, you can easily point and click the parts too. website: grainger.com
next, I need opinions on a prop. I know nothing about props.
also, throttle control ideas. I was thinking of using a old am radio with a servo. although, not sure if that is necessary.
Of coarse Ill be using HPI's plastic spur gear. 47tooth
shoot your ideas and suggestions and lets build a break in bench'
Thanks
Danny
Need your help~
Thanks
Danny
