Olds, I've seen some batteries that say you can charge them at 2C but I charge all mine at 1C. I.E. if it's a 5000mah battery, I charge at 5 amps. My batteries for my MERV are 2200mah and I charge them at 2.2 amps. About every 4th or 5th charge I'll charge at 1/2 that just for whatever.
So, it's still roughly the charge rate is the same as the capacity. A 5000mah pack charged at 5A for 1 hour. Not sure where the "1C" vs "1Amp" came into play.
the way I understand, charging generates heat
