Franger99 Active Member Messages 64 Mar 1, 2011 #1 ok so today i was playing with my savage and the rear differential i think broke. i turned the car over and took off the skid plate. i moved the wheels and the gears jumped. any ideas? i going crazy with this thing......thanks:deadhorse:
f1n3sse Well-Known Member Messages 929 Location philadelphia Mar 1, 2011 #2 if you put the truck on the ground and push it by hand do you hear grinding or feel skipping? best suggestion is to take the diff out and inspect it.
maximusraylius Well-Known Member Messages 2,123 Location liveing in mesa arizona can you say hot! Mar 1, 2011 #4 chewd the pinion gear or rounded the teeth on the ring gear as well..
Mickey just me Messages 3,098 Location Renfrew Ontario Canada Mar 1, 2011 #5 ill bet it is a b032 bearing failure that usually tears out the gears
