differential help!!
it will bolt to your savage 25 with a couple of changes. the outdrives are different so they will need to be swapped, as well as you will need x style bumper braces. also the bulletproof diffs are a slightly different gear ratio then the stockers.
i am new at this so be easy on me, but can someone give me a list of everything i need, i am trying to do a online order for everything tonight
thanks, is there a better way of doing it without ordering all that stuff, also the link for the skid took me to axles
the 4 gear spiders will hold up very well to the .28. as for a cheaper way yes there is but it will require disassembling the differentials. and changing the axle out drives. the 25 bumper braces can screw to the x style bulkhead but you have to watch the upper control arm pins for falling out
