difference between glow starters
kosss
Grafton Australia
Hi
i have been using a glow starter which you have to pull a lever to release it from the glow plug (i didn't think there was any other )
when i was talking to the LHS they told me they had one that you had to twist to release. it has a higher mah rating than my old one so it should last longer but are the twist off ones better or worse than the one i have
Thanks
you should see no difference in the two kinds, other than the other one will last longer, but I have had an 1800mah starter last months on a single charge, my brother has an 8000mah battery in his and well its overkill.
I have both. I like the twist offs becaues you can tighten a half cracked plug easy with it still on. (still need the wrench b4 you drive)Sweet for brake in and tight mills... IMO its nice to have two anyways. I run mine all the way down B4 I charge them and if you have 1 well, game over...
