Diff part question.
cOLD
I looked around the forums and the SS manual, but couldn't find a solution...
I took apart my rear diff because it didn't seem to be driving either rear wheel. When I got it out, one of the outdrives basicaly pulled out free. After opening up the diff, I found that the pinion gear ws in pieces and the pin had been reduced to particles. I removed the other pinion gear and that pin was in 3 pieces, so that the outdrive was spinning free inside the pinion.
So my question is, what is the part number or size of the pin that goes through the outdrives?
same size as the stock wheel hex's use, if you bought a kit it should of came with extra pins, actually I'm pretty sure everything on the truck uses the same "pin" size
