Did I kill the RX?
Guya
Hi
I noticed the antenna of the rx unit of the savage octane is broken.
So i am puzzeled what is tge best way to fix.
I can solder the wire ... But i have no idea if its a good fix.
After all it should work for only several tens of meters ...
From tge other hand i can change for a regular hk rx .. And use the simple controller .. After all the original controller is not something to be exited with ..
I do have an external failsafe unit to apply brakes if no link.
What do you smart guys think ?
Thanka.
Solder it and do a range check. I replaced the reciever in mine but the new one didnt work with the radio noise from the ignition so I put the old one back in.
Ok ..
So i soldered the wires .. But it is looding link after like 30-40 meters ...
Where can i but the wire for this rx ?
Thanks.
