ohmygahitscoby
Rollin' like a Big Shot
- San Jose, CA
- Thread starter
- #31
I've thought of using the C-Max series ones, but then they were out of my price range. The Sport Mac ones should do fine for me.
Thanks for the tips man! Definitely is going to help me.i recomend removing the motor mount, put the motor in then instal. you wont be able to with it mounted in the truck. the flux is 10 times harder to work on the the nitro trucks. also don't mount your batt boxes till your ready to run the truck otherwise you will end up removing them a million times (trust me i know lol)
also with the atomic hubs it doesnt come with the lower pin you need, just take and either use fuel tube or find some kind of spacer so you can use the stockers.
looks good man.
It's actually the monster pirate servo saver set, but I used some clutchbell spacers to remove the slack. Little did I know that it was the old school version, and it's much better to use just the spring with the X servo saver since it's adjustable. I'll probably change that out also.Coby, what bell crank are you using? Looks great BTW.
do you got a brand for them bad boys?
same slipper, just take and tighten that thing as much as you can... its useless.
