clutch bell
4x4
england
would any one know if the clutch bell is surposed to judder backwards and forwards on idle.it doesn't fall off though.is this normal?
thanks 4x4
make sure u have all the washers on the bell make sure its not to loose.. I know that the stock brass washer that comes with the mill gets all buggerd up and causes allot of slop so now I just use like 3 washers u might have to grind one down so it doesn't fit too tight
Yeah, there should be a very small amount of forward/rearward play along the crank, but not enough that you can see it while running.
